APX 6000
Texasranch1
Mount sterling
I just have a quick question for someone to answer. I recently took my APX 6000 1.5 model and put a 2.5 model screen on it. It lights up shows time. When i program it, that all works perfect, but it doesnt show channel or zone on the display. It only shows the time in the top left corner. Can someone help me fix it?
Texasranch1
Mount sterling
Put the 1.5 plate back on the radio. The radio knows it's a 1.5 so it doesn't recognize the keypad/display
If you need a model 2.5, sell the 1.5 and buy a 2.5
I get that, I just figured it was an easy swap I had an extra 2.5 display laying around. I don’t mind just the top display. The volume knob is broke but I manage with it. I have a new top display but idk if it will work with this model
n3obl
ØAES-1056
PA
It requires certain software to change the model number from a model 1.5 to 2.5. If this is an agency radio I would advise against such.
Texasranch1
Mount sterling
I’m gonna leave it alone. The only thing changing is I’m replacing the top control head as the volume knob is broke so you have you to remove the battery to turn off the radio if it doesn’t require software to change it
n3obl
ØAES-1056
PA
you can change the control top without needing a model change. For the back display to work it needs to be made a model 2.5 codeplug.
Texasranch1
Mount sterling
So I have an out of service apx6000 2.5 model control top, I tried to install it on this radio. Once installed the codeplug on the radio screwed up, I tried to reprogram but still nothing. When inserting the old control top back in, it works as it should
n3obl
ØAES-1056
PA
The control top should not have screwed up the radio. I’ve swapped numerous tops even between multiple radios with no issue.
You got something else going on there.
Texasranch1
Mount sterling
I found out my problem after doing some research. The control head i have came from a 7/800 mhz radio and my units are vhf
Texasranch1
Mount sterling
so quick question is there a setting in the cps that only allows your channel selector to show certain channels? i cannot find it if there is one
