APX 7000 Bluetooth issue
Hectomilan
California
So I recently installed the Bluetooth board to my radio, the Bluetooth option is enabled in the flashcode. The issue I am having, i don’t see the search devices / Visibility option on the radios Bluetooth Menu. I tried searching for any settings on CPS R30 and no luck. Please help thanks.
N4DES
Retired 0598 Czar ÆS Ø
South FL
There are a number of items missing from the BT Options menu including the PAN Network Base IP Address.
This is common with radios that have been hit with the D at some point in their lives or is missing QA00583 Bluetooth Operation.
rescueman433
Is that an APX7000L? What firmware is in the radio? Usually under the Bluetooth settings tab there is a Bluetooth Pairing type option that you need to select, LF MPP & Standard but I don’t see that option in your software.
y85csm
Electron Wrangler
Wrong side of the tracks
Does your radio have the BT antenna on the back of the speaker grill??
Early 7000s didn't have the antenna if it was ordered without BT.
This was the case on my 7000.
K2NEC
NA
The APX7000L never came in a UHF split, they were only VHF/7-800
Hectomilan
California
The feature is enabled.
Hectomilan
California
The firmware on the radio is currently R24.00
And the model number is H97TGD9PW1AN.
Hectomilan
California
That’s a good point I am
Not sure this is want I was asking my self what it connects too.
Hectomilan
California
Idk if this needs to be connected to anything can one or you verify if you have the 7000 with the Bluetooth feature. And see if this goes connected to anything? Thanks.
GTR8000
NY/NJ Database Guy
BEE00
On the right is what the BT board looks like when properly installed. It needs to be fully seated so that it clicks into the big white connector on the VOCON (hidden underneath that green cover on the radio to the left). Nothing gets connected to the top of the BT board, the antenna is built into the speaker module, that's what those two contacts on the BT board are for.
GTR8000
NY/NJ Database Guy
BEE00
Upon further inspection, someone who didn't know what they were doing played with Depot CPS and added QA03344 LTE Operation, which is not a valid option for a regular APX 7000. That's why your BT options look funky, and probably why the BT board isn't functioning properly. 🤦‍♂️
