APX APX 7000 - Yellow LED when RXing not working
I have a strange issue with my APX 7000. I noticed starting yesterday the yellow LED next to the channel knob is not working. The strange thing is when I turn on my radio and when it goes through the startup I get the red and green LEDs so it appears the LED is working but I am not sure why it is not working when I am RXing audio. I have checked in the CPS under all conventional personalties and have ensured that "Busy LED" is checked. I am also on the Default Profile where "Disable Lights" is checked off which is the default. I did recently update the firmware on my APX 7000 to R28. After doing that it worked for a short while but now it is not working again. Any ideas on how to get it to work, could it be a hardware issue?
n3obl
Ø
PA
No I do not get a light on trunking receive unless encrypted.
chrismol1
P25 TruCking!
i just realized mine isn't either on a trunking system, it is working on conventional though. I'm wondering if its an FW issue
In your case of trunking, there is a firmware update released in R32 to fix the issue of intermittent trunking busy light indication
For the OP, you say issue became apparent after the firmware was recently updated. That's not surprising, as often there is something that breaks on every update. When they added this feature to trunking, two versions later, there was an update in another 2 to fix the indication as it was intermittent. You may have to upgrade a version or so to see if the issue is resolved, I didn't see anything in a quick glance on the version log but that doesn't always mean they aren't screwing with something.
n3obl
Ø
PA
Im at 26.04 so thats why it doesnt work for me.
chrismol1
P25 TruCking!
That would explain it... My 7000 is on r31, which version of FW was the one that would cause Boot loops so i can avoid that if its not 32 or higher?
Get off R31 ASAP= Ticking Time Bomb. So bad, Motorola removed it from distribution. Get it on R32+ as soon as you can.
APX radios with 2023.2 Firmware / R31.xx.xx (R31.00.00 thru 31.02.00) may enter a continuous power cycling condition. Symptoms may not be seen immediately.
  • MTN-0149B-23.pdf
