APX 8000 vote scan
Trailblazer43
Washington, DC
I am having issues programming vote scan for conventional P25 system. When editing the scan list the P25 conventional channels are showing up red but the analog channels are showing up as usable. I cannot figure out why the P25 conventional channels are not able to be used. Appreciate any help/guidance.
Trailblazer43
Washington, DC
I also have a question about vote scan for analog conventional channels and wanted to know if it is possible to set up vote scan for these type of channels. I tried adding such channels to the scandal list and they were coming up as red and unable to be used. Does anybody know if it is possible to set up a vote scan for analog conventional channels or just for conventional P 25 etc. Thank you for assistance and appreciate any guidance of suggestions that could be helpful.
mountaincomms
Vermont
It is possible to set up Voting Scan for analog channels - I run it on a daily basis since our state police agency uses an analog multicast system. When configured correctly, it works just like roaming would on a digital system. That is, of course, provided you have the Conventional Voting Scan option enabled in your flashcode (assuming you do).
You cannot, however, have both analog and P25 channels in the same Voting Scan list as that will be marked invalid by CPS. I would advise creating two separate personalities, as it sounds to me like you might have analog and P25 in the same one. This will make things easier to configure.
Check out the attached screenshots from APX CPS which discuss valid field configurations if you haven't already. There's a lot to pay attention to, and it's important to remember that your personality, scan list, and zone/channel config must all align. Send a screenshot if you're still having trouble.
