APX APX 900 talkgroups in a scan list
W4KRR
Coconut Creek
In the APX 900, how many talkgroups can be put in a single scan list?
Can you put talkgroups from different systems in the same scan list?
TIA.
GTR8000
NY/NJ Database Guy
BEE00
- 50 talkgroups in a Priority Monitor scan list (one system only)
- 250 talkgroups in Multi-System Talkgroup and Intelligent Priority scan lists
- 30 channels in a Conventional scan list
You can include talkgroups from up to 5 systems in a Multi-System Talkgroup or Intelligent Priority scan list, however you are still restricted to 50 talkgroups per system. You can also mix conventional channels into those scan list types (up to 30), however the hard limit of all scan lists members is 250 regardless of type.
Intelligent Priority is nothing more than the original Multi-System Talkgroup scan list type, but with the ability to select Priority 1 and Priority 2 members. Those can be from any system or conventional channel in the scan list, however the caveat is that if the scanner is dwelling on System A's control channel, it's not going to have any awareness of what is going on with System B, System C, etc. Same concept applies if there are conventional channels in the list; if the radio has landed on one of those, it won't have any awareness of any trunking activity, and vice versa.
W4KRR
Coconut Creek
I've noticed that on the APX 900 that the signal strength indicator is missing from the display. Is this because it's programmed for non-affiliate scanning?
GTR8000
NY/NJ Database Guy
BEE00
If you have it programmed for non-affiliate scan, the RSSI indicator will not appear. Only in trunking mode.
GTR8000
NY/NJ Database Guy
BEE00
No one hates bad info being put out into the world more than me, and so I have to double back to correct myself! :oops:
The limit of conventional channels in a Multi-System Talkgroup or Intelligent Priority scan list type is 10, not 30. All other info in my post is accurate.
KE4ZNR
Radio Geek
Kudos brother. Been there too many times where I have to look at myself and say in a Fred Sanford voice "YOU BIG DUMMY!" :ROFLMAO:
