APX Can read radio. But won't write back.
FFPM571
Nashvillle
did you try to reload the original codeplug before you made changes? I hope you saved it
N1XDS
ÆS Ø
You may have to make another radio file or see if someone can give you another radio file to see if the radio accepts it if not i would call Motorola tech department and see what they say or can help with.
FFPM571
Nashvillle
Motorola won't really do anything over the phone. They will have you send it to the Depot.. The problem is twofold AN revision APX6000 are not being supported anymore unless under a service agreement, and the other is if it has been touched by depot software by someone not Motorola you may not get it back with what you have in it now
hitechRadio
What version CPS are you using? Have you tried the Latest CPS? Have you tried a FW refresh?
GTR8000
NY/NJ Database Guy
BEE00
Unless something has recently changed, the 6000AN is supported by normal flat-rate Depot repair until the end of this year.
FFPM571
Nashvillle
I have to check my Email.. It might have been the 7000... either way they are getting long in the tooth to get repaired at the depot. Sunny may be doing some work on them
