APX connection issue
19sargeusmc56
1st hiccup with APX....specifically v38.0.07....the thing doesn't connect to the radio. Disconnect the setup from the workstation and connect to the laptop, boom. The external hardware is fine. I've been programming this radio with this computer quite regularly without incident.
Went as far as to uninstall the prog cable and the software and re-iinstall everything with no joy. The device manager shows that the "device is working, referring to the programming cable. Get good USB mount & unmount tones.
Never had to set a com port in APX....it always seemed to find the radio no sweat.
Any suggestions would be appreciated. Help file had nothing for me.
wgbecks
NE Wisconsin
Connect your APX to yourworkstation using the USB programming cable, power on the radio, verify the you receive the USB enumeration tone when powering the radio. Open a command prompt, submit "route print -4" without the quotes.
Copy and post the information that is displayed from the above operation back to this thread for analysis.
19sargeusmc56
Well, after being off for an hour, the radio was then able to connect. I donno what happened.
Thx for the response
PARTHCITY
It happens sometimes. At least for me it does. Sometimes it's best to just leave it alone and try another day.
