APX CPS Export
jobro3082
Is there a way to export your code plugs and feature set from APX CPS? I’m running the latest version R26 and have all my code plugs for all our different APX radios 6000XE, 4000, 8000, etc. what I’m trying to accomplish is making sure everything is set up correctly. Why?? So we can go in and write our codes we have an outside agency that does it but we have been having some issues digital Interop not working some features we want not in the systems blah blah blah…. I’m trying not to comb thru 12 different programs suppression/FMO/ all the other divisions and would like to export and see features and programs… possible? Thanks I’m advance!
jobro3082
Ok, so one issue we had was the national digital channels you could hear but not transmit. I was aware of the handouts and info under tools but it doesn’t reflect this. We also have some backup frequencies programed into the radios that were not correct and it doesn’t show them as well..
Tech21
Are you referring to NIFOG channels for the "national digital channels"? Here is the manual that tells you exactly how to set them up, what they should be named.
The export method creates an xml file which excel can open but it doesn't put in an friendly, easy to read format. What you can do is essentially build out your codeplug in excel by copy and pasting. CTRL + Shift will allow you to select your whole table in CPS and paste over to excel and vice versa. It's time consuming the first time but it is a huge time saver when you gotta make changes.
