APX/XTL Programming Cable Schematic - Dog Just Ate Mine
RadRom
Ballarat, Victoria
Hi,
I need a schematic or picture of OEM APX/XTL rear accessory programme cable at USB end please. Cable dangled off table and dog ate it right at USB plug - See Pictures here.
HKN6163C is around $450 incl P&H to replace new here in Melbourne/Australia.
Bought new USB connectors, though there's extra cabling. Was a thinking of peeling/slicing the OEM USB plug.... But then again I might 'just' be able to salvage the USB connector.
Thankyou in advance.
n3obl
ØAES-1024
PA
Check out post 9 in this thread. Has the USB to the 26 pin pinouts. Plus the emergency jumper and speaker leads if you want. Then can just leave it hooked up to the radio.
RadRom
Ballarat, Victoria
Thankyou. I saw the thread but didn't see the post. Cheers.
RadRom
Ballarat, Victoria
Essentially the brown, orange and yellow wires do nothing and not connected... Hmm ok.
Probably explains why they sit outside the inner shield too.
THANKYOU!! :)
  • XTL5000 26-PIN AUX - PGM CABLE.pdf
n3obl
ØAES-1024
PA
I believe the same cable is for serial cable and hence why the conductors are there.
n3obl
ØAES-1024
PA
The serial port was for cables used for XTL (Astro25).
THe APX CPS was never designed for Serial port operation. Devices are read as a network device, hence USB operation or bluetooth.
