APX2000 very low audio
Charlie06911
Hey there! Couple weeks ago I bought an APX 2000 but noticed the radio has very low audio even with the volume at the top.
The issue solves when i attach a shoulder mic to the radio but is messy with my work.
Tried changing the inner speaker two times and no improvements
Any suggestions?
73’s
GTR8000
NY/NJ Database Guy
BEE00
Are you programmed for narrow band on a wide band channel?
He gets full audio with a speaker mic attached. That wouldn't be the case if it were a narrow/wide issue. Also, you have it backwards...the audio level is reduced if you program a narrow channel as wide. Wide programmed for narrow normally results in overmodulation of the audio.
Sounds like either a bad audio amp for the internal speaker, or the internal (radio) settings in the audio profile(s) are borked up, while accessory is fine.
You're right, missed that part.
Charlie06911
Have you checked the audio profiles?
Yes! Checked all the info on the codeplug and even cloned another radio with the same info and nothing!
Tried changing the internal speaker three times and it didn’t work, that makes me think it is an amp issue
But i haven’t found the piece 🫠
