APX6000 & APX900
willwilliams
Coalhurst
Hello everyone. I have a APX6000xe and a APX900 that wont read all of a sudden. we can hear them connect and they show up in the device manager but will not read at all. Both radios are legit and have not been altered since they were purchased. any ideas what might be causing this? We can read & write others no problem just these two for some reason are acting up.
AEFI
East Valley San Bernardino County
Probably have a bad cable. Try using a different usb port or check if the port on cps is right also check if your codeplug version is higher than your cps version if so get a higher cps.
willwilliams
Coalhurst
So the cable is good. If we turn off WIFI and disconnect the Ethernet cable from the computer then it reads just fine.
willwilliams
Coalhurst
It’s only on these Apx6000xe an which are on ver 36 something as that’s a high as we can go. The 900 we figured out and the radio was actually buggered.
wgbecks
NE Wisconsin
Oh? How dose one fix that
The first step is to determine if the interface metric is the issue. Connect your programming cable and turn on the radio.
Now open command a prompt and submit "route print -4" without the quotes. Verify the Motorola APX Series Radio appears
in the interface list
Interface List
28...6c 24 08 e6 9a bb ......Intel(R) Ethernet Connection (16) I219-LM
17...0a 00 27 00 00 11 ......VirtualBox Host-Only Ethernet Adapter
7...60 dd 8e a5 e4 f3 ......Microsoft Wi-Fi Direct Virtual Adapter
21...62 dd 8e a5 e4 f2 ......Microsoft Wi-Fi Direct Virtual Adapter #2
4...9a 95 92 5d 51 5f ......Generic Mobile Broadband Adapter
38...60 dd 8e a5 e4 f2 ......Intel(R) Wi-Fi 6E AX211 160MHz
71...0a 00 3e 35 18 23 ......Motorola APX Series Radio #2
13...60 dd 8e a5 e4 f6 ......Bluetooth Device (Personal Area Network)
1...........................Software Loopback Interface 1
Now locate the APX Serial Link 1 Addresses in the IPv4 Route Table while making note of the PC's own network
address (192.168.0.100 in my case) that will have the least cost route.
IPv4 Route Table
Active Routes:
Network Destination Netmask Gateway Interface Metric
0.0.0.0 0.0.0.0 192.168.0.1 192.168.0.100 30
0.0.0.0 0.0.0.0 192.168.128.1 192.168.128.2 55
127.0.0.0 255.0.0.0 On-link 127.0.0.1 331
127.0.0.1 255.255.255.255 On-link 127.0.0.1 331
127.255.255.255 255.255.255.255 On-link 127.0.0.1 331
192.168.0.0 255.255.255.0 On-link 192.168.0.100 286
192.168.0.100 255.255.255.255 On-link 192.168.0.100 286
192.168.0.255 255.255.255.255 On-link 192.168.0.100 286
192.168.56.0 255.255.255.0 On-link 192.168.56.1 281
192.168.56.1 255.255.255.255 On-link 192.168.56.1 281
192.168.56.255 255.255.255.255 On-link 192.168.56.1 281
192.168.128.0 255.255.255.0 On-link 192.168.128.2 311
192.168.128.2 255.255.255.255 On-link 192.168.128.2 311
192.168.128.255 255.255.255.255 On-link 192.168.128.2 311
224.0.0.0 240.0.0.0 On-link 127.0.0.1 331
224.0.0.0 240.0.0.0 On-link 192.168.56.1 281
224.0.0.0 240.0.0.0 On-link 192.168.0.100 286
224.0.0.0 240.0.0.0 On-link 192.168.128.2 311
255.255.255.255 255.255.255.255 On-link 127.0.0.1 331
255.255.255.255 255.255.255.255 On-link 192.168.56.1 281
255.255.255.255 255.255.255.255 On-link 192.168.0.100 286
255.255.255.255 255.255.255.255 On-link 192.168.128.2 311
Persistent Routes:
None
