Apx6000 bluetooth
wildbillx
Cape May, NJ
Has anyone had any luck with a Bluetooth ear piece for just RX? I have tried the Moto H500 and a Platonics one with no luck. I have connected with my Chinese made Bluetooth shower speaker though. I am looking for an ear piece for just RX if anyone has info. Also do not want to spend more than $40. Thanks
MTS2000des
5B2_BEE00 Czar
What firmware is your APX6000 running? You need to be running HOST version 11 or higher (current is 12.05) to use an off the shelf Bluetooth headset. Previous versions only allowed you to use "mission critical" Bluetooth headset pods.
Used a standard Plantronics $29 POS with a 6000 running 12.05 this past weekend.
wildbillx
Cape May, NJ
I have ver 11.01 but will not connect to either of my bluetooth ear pieces, But will to my bt speaker. Can you let me know the model number of the Plantronic please, Thanks
talviar
Uniontown, PA
I had intermittent issues with off the shelf bluetooth gear on version 11 firmware. upgraded to version 12 and problems went away. might just need to bump the firmware before you go spending more $$$ on accessories.
As always your mileage may vary and no warranty expressed or implied with my posting!
Later
T
wildbillx
Cape May, NJ
Ok well updated it to 12.05 and still no go on the Motorola H500, Plantronics Explorer 233, or avantree Sacool ear pieces. If anyone uses a cheap Bt ear piece please post model number.
wsykes41770
Memphis, TN
I can't remember off the top of my head where in the codeplug the setting is, but there is a box that needs to have the correct setting. It defines what type of Bluetooth accessories to accept, 1) proprietary Motorola equipment, or 2) Commercial Off The Shelf (COTS) equipment. The COTS setting also accepts Motorola proprietary as well. I want to say the field is under Radio Wide, but it may be Radio Egronomics Wide. I don't have my copy of the APX CPS in front of me otherwise I'd know for sure.
