APX6000 Programming NON-Affiliate Scanning
JimD56
KO9JAD/Fire Lieutenant/Paramedic
Davie, FL (Miami/Fort Lauderdale Metro)
I have the APX CPS and programmed my own APX4000 UHF Analog.
But, How hard is it to program an APX6000 trunking system 700mhz P25 Phase II TDMA.
Obviously, NON-Affiliated and receive only and NO Encryption?
This is the System
KE4ZNR
Radio Geek
But, How hard is it to program a trunking system 700mhz P25 Phase II TDMA.
This is the System
If you are referring to your UHF 400Mhz APX 4000 then it would be impossible to program a 700Mhz P25 TDMA system into it as that radio is a single band only radio. You would need a multi-band radio with the TDMA option in the flashcode.
JimD56
No Sir, I am speaking of an APX6000. I was just saying I have programmed an APX4000.
KE4ZNR
Radio Geek
Ok then your initial post was unclear.
You still need to have the TDMA option in the flashcode before a TDMA system can be programmed into the 6000. How do I know? Because I have a couple thousand 6000s & 6000XEs that need to have that option added to the radios before they can handle a statewide system that will be migrating to TDMA soon.
JimD56
YES TDMA is in the Flashcode. So I can I program for NAS at my desk at home.
