APX6000XE stuck in keypad lock
Motorolaguru
Hello! I have a APX6000XE and it seems to be stuck in a keypad lock? I have flipped and pressed every single button/knob on this radio and I cannot get it to get out of this lock? Does anyone know what the problem could be? Thanks!
Motorolaguru
When I flip the ABC switch the top screen white light comes on, but when I flip the switch below the channel knob it does not light up is it supposed to light up when the switch is flipped?
K2NEC
5F6
“Could not find a radio connected to USB port” but when I use the cable on my APX 4000 it reads fine.
The keypad lock is a pure coincidence. Has nothing to do with reading the radio. Is it an OEM cable? Are the 6000XE contacts clean and without debris?
Depends what its programmed to. Could either be unprogrammed, blank, or some other function that isnt applicable to that channel.
Is this your 6000XE that you are messing with? Because if it is, you should know what the buttons and switches are programmed to. If its not, id reconsider messing with someone elses radio.
Motorolaguru
Yes this is my radio I just purchased it off of eBay I’ve already contacted the seller and waiting a response but I figured I would ask for help from here while I waited.
Motorolaguru
Is this your 6000XE that you are messing with? Because if it is, you should know what the buttons and switches are programmed to. If it’s not, id reconsider messing with someone elses radio.
As far as the cable it is one I purchased from BlueMax49ers and I will try cleaning the contacts the contacts worked with a mic I tried on it.
nhfdcadet
GCT-1
New Hartford, Ct
do you get a bonk when you press a button or no response at all? Any chance you can get the thing into service mode? (Sometimes keypad lock isn't programmed to lock the sides)
dickie757
Wired
Out of range
Does it have a display? If so, try pressing the d-pad right button to see if lock/unlock is on a different page. That's where I put it, three pages over.
Motorolaguru
Service mode is a no go, every button is locked but the emergency and PTT
K2NEC
5F6
Did you clean the contacts and try to read the radio
d119
Patch & Channels Clear...
EM1's guest house.
Sounds like someone sold you a dud, especially if it's acting like that and can't read/write.
You should be able to enter service mode regardless, and if any buttons at all generate a tone, they all should. Hope you can get your dough back.
Respectfully, your username might be a little off if you're asking these kinds of questions. :)
Remember kids: You're buying the seller, too.
Motorolaguru
I mainly mess with the older Motorolas I’m kinda new to the APX line so I apologize for my newness. I’m going to be returning the radio and getting my money back. Thanks for your help!
