APX7000 intermittently not receiving a conventional Astro channel during scan.
jyp1911
Derry, NH
I am having an issue during scan with my APX7000 UHF2 / VHF potable radio. I have a Rx only conventional Astro channel programmed that will not consistently Rx during scan. If the scan mode is off, the channel is loud and clear. If the channel is the selected channel / priority one during scan mode, it will also Rx loud and clear. As soon as this channel becomes a non priority member of the scan list, it has intermittent issues and scan mode will not pick up the channel consistently. The radio's primary frequency band is UHF2 with VHF as secondary. The frequency of the channel is in the 482 mhz range. I have no issues with the other scan list members that are a mix of either VHF Astro, VHF analog, or UHF analog. I've deleted the personality in programming and started over with default values and I still can't get the channel to reliable receive during scan. This problem stumps me and hopefully someone can point out what I'm missing.
KevinC
The big K
Super Moderator
Home
Is the frequency in question P25 simulcast? If so set the digital modulator to CQPSK and see if that resolves your issue.
jyp1911
Derry, NH
I don't believe the frequency is P25 simulcast but I could be wrong. I will give it a try and see what happens. I can tell you that my UHF XTS5000 Model III has no issues with the same frequency when scanning it as a non priority member.
jyp1911
Derry, NH
Unfortunately that did not resolve the issue. I’m probably going to try and get it retuned and aligned but I don’t think that’s the issue since the channels all Rx fine when not scanning.
GTR8000
NY/NJ Database Guy
BEE00
I've seen this issue within the past year on a UHF conventional P25 channel with an APX 8000, however that channel was using encryption. I gave up on trying to figure out the issue after trying numerous things to get it working, and I haven't gone back to it because the channels weren't all that important in the grand scheme of things.
What firmware are you at?
jyp1911
Derry, NH
Firmware is r29.02.00
This channel does not use encryption. It’s a weird issue that I’ve never encountered before.
KevinC
The big K
Super Moderator
Home
Turning off priority scan fixed the problem. I’m guessing the radio doesn’t have enough time to decode the data to unmute in between priority samples.
Interesting. Thanks for updating us.
