APX7000 waterproof specs
TrunkLatcher
Hello,
I am aware (due to help on another thread) that there is the mil spec waterproofing (APX7000R) and the IP rated waterproofing on the APX7000XE. My real question is if I get a radio that is used (most likely it wouldn't have tags) what is the risk that the waterproofing would have been compromised?
When people do stuff to tag-less radios, do they generally mess up the waterproofing? How easy is it to mess this up if you open the radio? I really don't care about certifications, I just want something that works as waterproof.
Thanks.
blaze
For the standard IP waterproofing, there's no specific requirement for testing, so if the radio has been assembled properly I assume that's probably sufficient to maintain the seals.
However, assembling the radio properly isn't completely trivial. In particular, there are a few parts that have to be lubricated with special grease, and the six case screws have to be tightened to a specific torque (10in-lbs, if I recall correctly, which is *very* tight -- any tighter and the screw may shear off).
If you've got a used radio and you're worried, I'd open up the speaker grille, make sure it's been lubricated properly, and re-tighten the six case screws with a torque driver to make sure they're at the correct torque. And then I'd still try to avoid dropping the radio into any lakes.
Indiana16
Motorola Solutions test all the radio equipment in their testing lab in Plantation, FL. The APX radios come standard with the mil spec from what I understand.
blaze
No. The -R and XE models are milspec waterproofing. The regular APX models are IP67.
TrunkLatcher
I am almost certain that blaze is right. The main point of my op was essentially "how easy is it to mess this [waterproofing] up if you open up the radio?" From what I learned from blaze, there is a lot of care that must be taken to maintain this protection. Certifications are probably already irrelevant if it is a 123ABC1234 radio. I guess if I get the proper tightening tool (@blaze, what exactly is it?) and the grease (what is the official name?) that I could verify the integrity myself. Thanks for the help.
mikewazowski
Staff member
Forums Manager
Oot and Aboot
I think if you're that worried about the integrity of the seal, you'd be better off buying the radio from a reputable dealer.
