Yes, correct....I did confuse myself there. I try very hard to carry the batteries on the right, what works on both series of radios, for this very reason. Thank you for pointing this out so others do not make the same mistake.
Be VERY careful with using batteries with both sets of contacts on an APX. I have seen the second set rip out the battery contacts off of the board numerous times. Most often is the center battery sense pin but I have seen the ground and B+ pins ripped off too. They will still be present in the radio, but the contact to the board will be damaged and most of the time traces ripped off the board. We discovered this when several users complained that they lost their battery meter even after they did a recondition cycle. The contacts looked like they had been moved physically and when we opened up the radio, the pins were no longer making contact with the board. There was really no way to resolder them so they would be physically attached and strong. The user decided to save money and bought XPR batteries. After they got sent to the depot and the new "discount" rates, they decided it was cheaper to buy the correct battery.
We have seen this on both the APX1000 and APX4000 platforms on multiple users.
EDIT: This was with legit OEM Motorola batteries, not Amazon specials.
