ARC-250 question
wa8vzq
Minnesota
I'm recently started using ARC-250 with my BC785D. I can manually set the delay to 4 seconds in the BC785D but how do I set the delay using ARC-250? Mine doesn't seem to only allow me to change from 2 seconds.
Dan
Butelsoftware
Dayton Hamvention
In the RS232 communication setup make sure you selected the 'BC785' scanner model, by default the software is set to BC250 and that model only supports 2 second delay.
Gommert
h8tdigitalradio
Uniden Beta Tester
Six Feet Over
Hello,
Highlight the Delay Time sector where you want to change the time. On the top left is a Drop Down menu where you can select Delay Time. Or, you can double left click to change the Delay Time from the sector you highlighted.
HTH's
73
Dave AKA The Tripzter
