Arc xt & 396xt
6520tkp
The program (ARC XT) I bought with a 396xt scanner gives me an error message saying it cannot detect a 396xt scanner when I try to download the systems I created.
Any suggestions?
Thanks.
Kingmobileaudio
Lincoln, NE
Did you install the drivers from scanner master or did you let Microsoft install them? If you like give me a call and I can walk you through it.
Sent from my HTC EVO 3D using Tapatalk
Kingmobileaudio
Lincoln, NE
Auto never work for me. Go in to device manager and look under serial port to see witch one it's plug in to and make sure it's set to the same one and the bit rate is the same.
