ARC-XT vs PROSCAN
furbox
I own several BCD996P2 scanners. I was using ARC-XT for programming but realized none of the conventional NXDN channels were decoding. I do have the upgrade. When I tried PROSCAN the scanners worked fine. Both times I downloaded the database from RR. Is there something I'm missing in ARC-XT? I am using the paid versions of both software packages. I tried setting the RAN in the same column as ctcss, setting type to all and digital only. Any ideas?
Thank you,
Paul
K2PMS
WRMF733
