ARC15 Software
skywarrior
Tucson AZ
Hi All,
I recently started using this program for my BCT-15X and I am having a few issues. The main one is that even though I check the alert notification light and pick a color, the alert light does not come on. Instead the whole display flashes. Any thoughts as to the problem would be most welcome.
TIA
skywarrior
Tucson AZ
Tvengr, I do have the ARC-XT software so that is good. Whiskey3JMC, I followed the instructions that you pointed to, but alas the same thing is happening. The whole display blinks, but no alert light right above the volume knob. Don't really know what the problem could be???
skywarrior
Tucson AZ
OK, I have re-read the manual both the Uniden manual and the Easier-to-read manual done all of what they have indicated and still instead of the alert light flashing, the whole display flashes. I am thinking it might be an issue with the radio??
tvengr
Well Known Member
Baltimore County, MD
First, make sure you are ready to reprogram the scanner. I think it is time to try a reset. Turn the scanner off. Press and hold the 2, 9, and HOLD buttons while turning on the scanner.
skywarrior
Tucson AZ
OK, re-set the radio, absolutely no change. No alert light. While going over the posts here I did notice that I neglected to indicate I am trying to get the alert light function for a conventional system, it is not possible that the light only works on trunking or other system??
tvengr
Well Known Member
Conventional frequencies and trunked talkgroups are programmed the same way. It should work on either one. The only other thing I can think of is that the firmware could be corrupted. I would try reloading the firmware. If that fails, I would open up the scanner and reseat cables and connectors, especially those going to the front panel.
62Truck
Ordinary Subscriber
Ø
The alert light above the volume knob is part of the " BearTracker Warning System"
The BearTracker Warning System is a special part of the BearTracker System. When you press [HP/B], the scanner is set to alert you to transmissions of close by services. The BT display icon begins to blink. The BearTracker LED lights, and you hear a menu selected Alert Tone. Most highway patrol vehicles on the road today are equipped with a secondary radio system known as ‘mobile extender’ or ‘vehicular repeater.’ Whenever the dispatcher transmits to any vehicle in the district, ‘mobile extender’ in every car within the district is activated. Every 2 seconds, the scanner checks for activity on BearTracker Warning System frequencies for your state (see “Setting the BearTracker Options” on Page 67 for information affecting all BearTracker Warning system options) to set how many frequencies the scanner checks during each cycle). The BearTracker Warning System frequencies includes frequencies used by ‘mobile extender’ radios as well as by car-to-car, aircraft-to-car, and other special-purpose frequencies. You receive an audible (beep tone) and visual (flashing Alert light) alert whenever you are within an approximate three-mile radius of Highway Patrol/State Police units using a mobile extender unit.
62Truck
Ordinary Subscriber
Ø
Hi All,
TIA
This is normal, this what the display will do when you have that feature turned on. On the 15x only has one color on the display and will not flash any other colors.
