ARC250 and Win96 files
ka3jjz
Wiki Admin Emeritus
Bowie, Md.
Since we're getting close to that time of the year when folks take vacations, and there's been a few messages out on the boards about how to set up files, I thought I might offer the following;
The Capitol Hill Monitors have 2 pages - one for ARC250 files, the other for .p96 files - where you can download them, edit and adjust them to fit your needs. Even if the area isn't exactly the same, you can use
them as 'models' to create your own files. Note that the ARC250 files are in zip format, so you will need an unzip utility to uncompress them before use. The URLs are:
CHM ARC250 file library
CHM .p96 library
While we've gotten a few files, we could always use more, particularly from areas in northern Virginia not yet covered by a file. If you wish to share your files on these pages, please forward them to alan@henney.com
Make sure you note what area(s) they cover and which banks are used.
73s Mike
kg4rgn
New Kent, VA
acr250
SO WHAT ARE YOU LOOKING FOR...I HAVE SENT MOST OF WHAT I HAVE?
I HAVE ADDED MORE IDS FOR THE RICHMOND SYSTEM, THE YORK CO AND JCC CO DIGITAL SYSTEM IS STILL IN THE PLANNING FOR IDS STAGE, BUT WILL SEND THE FILE ONCE THE SYSTEM IS CLOSE TO BEING COMPLETED......
ANYTHING ELSE, PS I DID SPEND ABOUT AN HOUR AND PUT TOGETHER A NYC FILE..
LARRY W.
