ARC396 Software
hCorte
I'm using ARC-396 for my BCD396. I notice that I cannot use the ARC-396 software to read out and edit the list of locked out TGIDs from any of the systems on my scanner. Is this normal?…..that the ARC-396 software does not handle this task?
Henry
Butelsoftware
Dayton Hamvention
Locked out Talkgroups will have their lockout flag set to on. Click on a group in the system browser and then you will see the talkgroups in the right pane with the lockout column.
Gommert
Butel Software
hCorte
Gommert
Butel Software
Thanks for your answer Gommert…..but I was referring to that list of locked out TGIDs that is built when you do a SEARCH instead of a SCAN in a system. As you SEARCH, the IDs that you don't want to monitor, are locked out with the L/O key, and this constructs a list of the locked out IDs within that System. You can view this list under System Options. This the list I don't see in the ARC396 software.
Henry
