Are These From Satcom?
RadioDitch
Field Operations Member
Not Where You Think
vagrant
ker-muhj-uhn
California
I don't know about you, and although it has been years, the last time I visited a fast food drive through it sounded like that first recording...and somehow my order was correct.
The RadioReference Wiki is a good place to start for information.
Military Monitoring
Satcom
fires999
Hertfordshire, UK
Hi Radioditch,
Just to save confusion , Satcom can be the term used for monitoring the old 250mhz uplink/downlinks not often used by Military as once was - Satcom title also used when monitoring the Inmarsat link around 1500mhz (I know, it is a very loose explanation , but many people get confused between the two)
Few of us over here in UK monitor 1.5ghz - can be quite a process to set up but there are several good videos on YouTube - try searching Inmarsat Jaero L band
Good Luck,
Fires999
prcguy
I listened to the recordings and have never heard anything like that on UHF satcom so I doubt its that. Its extremely rare you will hear anything in the clear and if you do it will be FM mode and it will sound pretty normal. If its encrypted, which is 99.9% it can have a brief beep then the hiss of digital modulation and sometimes no beep, just hiss.
reconrider8
Eastern, NC
It's satcom but it's not satcom lol. It's inmarsat
spacellamaman
out of curiousity, what is happening with the beep? some sort of periodic data/timing update or something? the randomness of that has always made me wonder.
TampaTyron
Beep Boop, Beep Boop
Phoenix, AZ
LMR has similar where is sounds like "gleep shhhhhhhhhhh" then "gleep shhhhhhhhhhhhhhhh" etc.
