Rogers,I believe was upgraded to ARSR IIE, and is fed to both Houston and Ft. Worth ARTCCs.
Azel is an ASR-9. It serves DFW and Ft. Worth Center.
Anson is Secondary (SSR Beacon) only. it serves Ft. Worth ARTCC.
Sachse is an ASR-9 and serves DFW and Ft. Worth ARTCC.
Afton is a Secondary (SSR Beacon only) site fed to Kansas City, Memphis, and Ft. Worth ARTCCs.
Keller is an ARSR IIE, and serves Ft. Worth Center.
Although the above thread is old, I thought I would insert that the ARSR-2 have been upgraded to CARSR. Note that CARSR is NOT an ARSR-3 (nor is it a ARSR-4). CARSR and ARSR-4 are now the long range radars for ARTCC and air defense. Those still in the 1.240-1.370 GHz range, with 2 frequencies for ARSR-4 and 2 frequency pairs (4 frequencies, but the 2 per pair are only about 5 MHz apart) for CARSR. The rotation time remains 12 s (5 rpm). When close, due to signal strength, one can often see the signal continuously and not perceive the rotation.
Airport radar generally are ASR-9 or ASR-11 and can be found in the 2.7 to 3 GHz range if one wants to "hear" them. The ASR-9 use 1 frequency, while the ASR-11 use 2 frequencies (one of the ways to tell them apart). These are 4.8 s scan (12 rpm).
Air navigation radar TDWR (Terminal Doppler Weather Radar) located near (but usually not at the airport) for larger airports uses 5.6-5.65 GHz.
The surface detection radars for airport ground (where installed) use 9.0-9.2 GHz (ASDE-X, 4 frequencies) or 15.7-16.2 GHZ (ASDE-3, 16 frequencies). I have personally no experience with those other than seeing the rotating enclosure often atop an airport tower.
NWS weather radar (NEXRAD) operates in the same band as the ASR-9 and ASR-11 (2.7-3 GHz). these have a 6 minute repeat period of different modes on one frequency.
Both TDWR and NEXRAD (WSR-88D) are in radomes (smaller than those for the CARSR and ARSR-4).
