Aspen Acres Fire
UAT_978
I am hearing them run ops on MAC 11 and MAC 12. I have also heard traffic on S RIC FIRE on DTRS. These have come out of the Pueblo Simulcast, PPRCN and Cheyenne. I have not heard which Air/Ground frequencies are in use in the area. I am in the Springs so I am a bit far away. I have also heard them talking about using the Simplex 1-5 channels as well as Beulah Fire Tac (ENC).
Any other resources?
scanner_nut
Pueblo NIFC Dispatch Aircrew Guide https://gacc.nifc.gov/rmcc/dispatch_centers/r2pbc/PBC Aviation Briefing Guide.pdf
National Flight Following: 168.650. Aircraft transitioning into the area or checking in with dispatch will often use this first.
Per MAC 12 - air tankers will refill at KPUB. I am also seeing tankers RTB to KCOS.
119.575 is active
KPUB Airport Communications​
CTAF:​
119.1
UNICOM:​
122.95
ATIS:​
125.25
WX ASOS:​
PHONE 719-225-7029
PUEBLO GROUND:​
121.9 [0600-2200]
PUEBLO TOWER:​
119.1 257.8 [0600-2200]
DENVER APPROACH:​
120.1
DENVER DEPARTURE:​
120.1
CLEARANCE DELIVERY:​
120.9
Pueblo Tanker Base124.425Coordination for retardant drops originating from Pueblo Memorial.
scanner_nut
Rye evacuation coordination has moved to Rye TGs: 4290, 4291
scanner_nut
Integrated Incident Communications Plan (ICS 205 Block-Equivalent)​
Incident: Aspen Acres Fire (Pueblo / Custer Counties, CO)
Managing Dispatch Center: Pueblo Interagency Fire Dispatch Center (Padd / RMGACC)
Primary Trunked System: Colorado DTRS (Southeast / South Region Zones)
1. Command & Tactical Frequency Assignments (Ground Operations)​
Channel NameFrequency / TG IDTone / NACModeFunction / Assignment
Pueblo Inter Base173.6750 MHz (RM)141.3 PLFMNFederal/USFS Fire Dispatch (Methodist/Pisgah Repeaters)
MAC 11 SETG 4011DigitalP25Primary Command / Fire Operations
MAC 12 SETG 4012DigitalP25Secondary Ops / Medical & Logistics Support
S RIC CALLTG 4453DigitalP25South Region Interop Hailing / Initial Command Check-in
S RIC FIRETG 4454DigitalP25South Region Multi-Agency Fire Mutual Aid
S RIC LAWTG 4455DigitalP25Multi-agency Unified Evacuation Link / Roadblocks
S RIC EMSTG 4456DigitalP25South Region Medical / Mass Casualty Triage Interop
NIFC TAC 5166.7250 MHz (BM)192.8 PLFMNPrimary Ground Tactical (Line-of-sight Division Crews)
VFIRE 21154.2800 MHz (BM)156.7 PLFMNMutual Aid Staging / Base Camp Check-In
Pueblo Co Fire DispTG 1913DigitalP25Local Structure Protection Dispatch
Custer Co Fire DispTG 1153DigitalP25Westcliffe / Local Resource Dispatching
Pueblo Sheriff Tac 3159.1900 MHz (RM)146.2 PLFMNLocal Evacuation Support (Beulah / Rye Corridors)
2. Aviation Communications Plan (Fire & Air Traffic Control Integration)​
Channel NameFrequencyModePurpose / Assignment
Air Guard168.6250 MHzFMNNational Emergency / Aircraft Safety Override Only
Nat'l Flight Following168.6500 MHzFMNInteragency Flight Tracking (Check-in upon entering TFR)
Air-to-Air (Fixed)122.9250 MHzAMMulti-Engine Tanker / Lead Plane Coordination
Air-to-Air (Rotor)119.5750 MHzAMHelicopter Operations / Type 1 Skycrane Deck Traffic
Air-to-Ground 1167.4750 MHzFMNDirect Ground to Aircraft Tactical (Federal)
Air-to-Ground 2159.2850 MHzFMNVFD / State Asset to Air Coordination (Structure Ops)
KCOS Tanker Base120.4250 MHzAMPrimary KCOS Retardant Pit Logistics & Fueling
Nat'l Tanker Base122.6750 MHzAMSecondary KCOS Check-in (Nationwide Standard)
Springs Approach (S)124.0000 MHzAMPrimary KCOS TRACON (Southern Sector / General)
Springs Approach120.6000 MHzAMSecondary KCOS TRACON Approach
KCOS Tower119.9000 MHzAMColorado Springs Local Tower Control
Denver Approach (PUB)120.1000 MHzAMKPUB TRACON (Handled by Denver Approach D01)
KPUB Tower119.1000 MHzAMPueblo Memorial Local Tower Control
3. Critical Assets & Logistics Infrastructure​
  • DTRS Tower Sites: Ground operations must monitor system affiliation. Primary system access relies on Baculite Mesa (Site 1-32) for the eastern footprint, and Methodist Mountain (Site 2-11) or Rocky Point (Site 1-12) for the western/mountainous footprint.
  • Communications Contingency (PACE Plan):
    • Primary: DTRS MAC 11/12 and S RIC suite for Command; NIFC TAC 5 for Division Tactical.
    • Alternate: If DTRS fails or units move out of site footprint, Command falls back to VHF Pueblo Interagency Base.
    • Contingency: VFIRE 21 established as the line-of-sight incident-wide hailing channel.
    • Emergency: Air Guard (168.6250 MHz) for immediate life safety/Mayday calls.
UAT_978
Its interesting that they specify those DTRS sites. I can tell you the MAC 11/12/S-RIC-LEO/S-RIC-FIRE are coming out of Pueblo Simulcast, PPRCN and Cheyenne as well as probably other sites out of my range.
scanner_nut
I agree, Baculite Mesa hosts several conventional public safety and amateur systems, while the primary regional trunking coverage is anchored by Pueblo Simulcast with the MAC talk groups being carried across the sites you listed.
scanner_nut
**THIS IS UNOFFICIAL - I CREATED THIS USING DIFFERENT OPEN SOURCES**
UAT_978
flight following is very active and loud here in the springs.
scanner_nut
Integrated Incident Communications Plan (ICS 205 Block-Equivalent) Rev2 UNOFFICIAL MAY CONTAIN ERRORS
Updated as of 7/3/26 1700Z
Incident:
Air Attack124.475AMAir Attack
Section 3 IC Status Sources
Incident Table | InciWeb
Pueblo Emergency Status Board | Pueblo County Sheriff, CO
https://custersheriff.colorado.gov/
Sources:
FCC Callsign WQSL759 (STATE OF COLORADO)
https://www.radioreference.com/db/sid/329
scanner_nut
Ummm. This is more AI slop. Baculite Mesa DTR doesn't exist nor does Pueblo Sheriff VHF Tac-3. Please STOP posting this AI garbage.
Also, these talkgroups don't exist.
Thank you for identifying these errors, the HITL (me) did not go through the results of my prompts and queries to verify the accuracy before posting. I have corrected all identified errors in this mornings post. Have a great Independence Holiday!
scanner_nut
MAC 09 - TG 4008 - Identification, Accountability, Command and Control of Land Based Fire Attack Resources. Structure South is IC for these assets. Asset Type charts found here - Equipment, PMS 200 | NWCG
natedawg1604
Colorado
Are there any actual scanner feeds covering anything relevant to these incidents?
