Wondering if someone has some time and patience to help a newbie on his way to get up and running on APRS with a Yeasu FT-8800R and MFJ-1270B
I've tried looking for a guide of some sort on the web but have come up short.
Important to note, I don't have GPS hooked up yet and right now I'm trying to confirm my Radio<->TNC connection is good. I attempted to make my own cable hence the reason why I'm stuck at this point (not to mention this is foreign to me.) Once done I may have to make my own cable from my Garmin to the TNC as well so I will be looking for those pin-outs next.
On to where I'm at.
The Yeasu and TNC are both set 1200baud. From my Win95 machine using hyperterminal I can connect to the TNC and get the following output initially.
MFJ ENTERPRISES INC TNC-2
AX.25 Level 2 Version 2.0 + FAX
Release 1.2.6 02/17/89 - 32K RAM
Checksum $1C
cmd:
I was able to successfully run the "MyCall" and "Beacon Every" commands so I'm comfortable with the PC to TNC connection/communication.
I've set my Mobile and HT on a vacant frequency on low power so I can try to see if something comes alive. (don't want to just blast the normal APRS freq until I know things are good)
I'm have no idea where to go next as far as testing proceedure and configuration settings but what I do know is if I cycle power to the TNC, I get a momment of snow/static on the Right side of my FT-8800 (I have the packet set to right side only).
Any help is greatly appreciated.
Thanks in advance!!!
Terrence - K5TBO
On to where I'm at.
Checksum $1C
cmd:
Terrence - K5TBO
