Hello,
I recently purchased a Radioddity CS-47, a Firestick FS-3 3' antenna, the Firestik K4-8R9 with Fire-Ring cable (9 ft), a Marketty ss-3H Antenna spring and a hood mount.
After getting everything installed, I went to tune the setup and am having difficulty. The SWR for both Ch. 1 and Ch. 40 are identical at about 3.5. Adjusting the tuning screw on the top of the Firestick has no impact on the SWR reading at all. I've run the screw all the way in as well as all the way out. No change.
I'm not sure what could be causing this. Can someone point me in the right direction to try and solve?
Thank you.
Thank you.
