Astro Saber Tool
Armadillo5
North Texas
The tool that is used to loosen the screws on the bottom of an Astro Saber to remove the housing has a part number that I cannot locate on the Moto Website.
Anyone have the part number for this tool and what it is called?
Looking to change out my housing's on a few radio's and need the tool.
Thank you for the help.
FFPM571
The Mid South
Find an old flat blade screw driver and file a slot in the blade.. Its cheaper and works just as good.
firephoto20
California
They have the Bits at "Ace hardware" not sure if you have one by you but there like 4 bucks...maybe try home depot..
JnglMassiv
Chicago / 016
I used to use the tips of some small needle-nosed pliers.
Until I got a set of 'tamper-resistant' bits a couple years back, that is.
Here's a good shot of a typical set. The saber bit is bottom row, second from the left. They are widely available for a reasonable cost (should be under $20) and pretty useful for all sorts of purposes.
