Astro Spectra Flashcode
Seadoo
Anyone know what flashcode is required for a astro spectra to receive digital imbe trunked in a 800mhz model . If so can you post it here. Thanks
PJH
the flash code needs only the IMBE Q806? option and the flavor trunking you need.
Standard disclaimer: If you don't know how to safety program a trunked two-way radio, don't bother. You can only scan 10 talkgroups at one time, and should the system be setup for automatic unit polling, it will turn your radio into a paperweight and you won't be able to do anything to revive it.
Get a scanner.
Get a scanner.
15 talkgroups, with a little tweak :)
PJH
This is true...but as a heads up, doesn't play properly in a HRR setup :)
Seadoo
Thanks for the info guys. I saw one on ebay, that supposedly came off of a FHP police motorcycle, but that cant be because down here in fl the motorola system was astro digital trunking. and the radio on the ebay site does not have the IMBE option. Thanks again.
