Astro Spectra help
toolman60
Is this radio capable of narrow and wideband? I just wanted to double check as it looks like it is variable programming for channel spacing.
DO4JKF9PW5AN_UCM flashport: 1400010000003
Now the hard part would someone please give me the part numbers of needed parts to do remote mount for the radio. I have tried to find a cable part number in the astro book but overlooking it or it not in there. I know I need the mounting hardware , I just need the cable part numbers.
Tim
clbsquared
Isle of Wight County
You need an inter connect board. This might be an old part number, but it should get you where you need to be. HLN6344E
And then you'll need a remote mount housing HLN6432B
And last, you'll need the control head cable HKN4356B
KG4INW
Midlothian, VA
You're welcome. They're good solid radios as long as the leaky capacitors have been replaced.
