ATC Radar Sites
slabonte
Here's the sites you may see in NY:
Buffalo(Dansville) FAA ID: DSV Type: ARSR-1E
Scan Time: 10
Max Range 200
N 42.63836055555556, W 77.65306
Newark FAA ID: EWR Type: ASR-9
Scan Time: 5
Max Range: 60
N 40.673273611111114, W 74.18571277777778
White Plains FAA ID: HPN Type: ASR-9
Scan Time: 5
Max Range: 60
N 41.072786111111114, W 73.71541111111111
New York FAA ID: JFK Type: ASR-9
Scan Time: 5
Max Range: 60
N 40.63962222222222, W 73.76642777777778
Du Bois FAA ID: QCF Type: ARSR-3
Scan Time: 12
Max Range: 200
N 41.07026666666667, W 78.55041111111112
North Truro FAA ID: QEA Type: ARSR-4
Scan Time: 12
Max Range: 250
N 42.03455 W 70.05439
Cummington FAA ID: QHA Type: AN/FPS-67B
Scan Time: 12
Max Range: 200
N 42.47472 W 72.96799
Gibbsboro FAA ID: QIE Type ARSR-4
Scan Time: 12
Max Range: 250
N 39.82477055555555, W 74.95414333333333
The Plains FAA ID: QPL Type: ARSR-3
Scan Time: 12
Max Range: 200
N 38.88225 W 77.70308333333334
Benton FAA ID: QRC Type: AN/FPS-67B
Scan Time: 12
Max Range: 200
N 41.35740416666667 W 76.29298777777778
Riverhead FAA ID: QVH Type: ARSR-4
Scan Time: 12
Max Range: 250
N 40.87868 W 72.68710
Utica (Remsen) FAA ID: QXU Type: ARSR-4
Scan Time: 12
Max Range: 250
N 43.34550 W 75.24897
Newburgh (Stewart) FAA ID: SWF Type: ASR-9
Scan Time: 5
Max Range: 60
N 41.49058333333333 W 74.10566388888888
St. Albans FAA ID: QHB
Scan Time: 12
Max Range: 200
N 44.78172 W 73.06564
Bucks Harbor FAA ID: QYA
Scan Time: 12
Max Range: 250
N 44.62943 W 67.39537
Manchester FAA ID: MHT
Scan Time: 5
Max Range: 60
N 42.950013 W 71.299194
If you manage to correlate any of these to their correct II/SI identifiers, please share.
slabonte
While trying to match up what I had with these, I came across what appears to be another one, at the old S. Weymouth NAS (42.158254 -70.933388).
Lynch_Christopher
Winthrop, Ma
If I am not mistaken I believe that radar site at the old South Weymouth NAS is actually a NEXRAD Doppler Weather Radar (WSR88-D).
jfr
Walpole, Ma
The radar at S Weymouth is actually a Terminal Doppler Weather Radar (TDWR), the higher-freq cousin to the WSR-88D. It has higher resolution (but lower range) and is used in conjuction with large Metro Airports (Logan, in this case) to detect wind shearing.
Terminal Doppler Weather Radar - Wikipedia, the free encyclopedia
bobradar
Northampton Ma
New FAA radars
Any of the sites listed with ARSR1/2 or FPS are being replaced with C.A.R.S.R. systems, which stands for Common Air Route Surveillance RADAR.
This is being done through out the country.
Also when these system are finished being upgraded the ARSR-3 RADARs will be replaced.
I went from working on a FPS for 25 years to a CARSR on 11-2012 at Cummington Massachusetts.
D
DaveNF2G
Guest
That explains why Cummington never shows up as a possible site in Beamfinder.
MikeMike
CT
Coastal CT PP GS
I am starting to dig deeper into PP after only recently starting to share 24/7 using GS id "mN". I'm interested in working on the Beamfinder / Radar locations and plan to try and correlate the sites posted above.
Just curious if anyone has done any more work on this lately and is willing to work together to get this going for the New England area?
-Mike
D
DaveNF2G
Guest
You should join the Planeplotter group at Yahoogroups. Beamfinder and the issues with using it in the USA have been discussed there extensively. Some locations/idenfiers in the northeastern USA and eastern Canada have been published.
jjwiseman
Los Angeles, CA
I have started an open directory of ATC radars at https://github.com/openairdata/atc-radar
I've used sources I found online to construct the initial version of the directory, containing 540 radars in North America and Europe, and it's my hope that by keeping it in one place, making it open for anyone to use, and making it easy for everyone to add new information or fix mistakes that it will become a useful and up-to-date resource for everyone.
Colorado
I must be missing something. I have gone to that link and cant figure out how to display the list. Where am I going wrong?
jjwiseman
Los Angeles, CA
First, I moved the repository to https://github.com/open-air-data/atc-radar (I left a short message at the original URL with the new URL).
The actual data file is at https://github.com/open-air-data/atc-radar/blob/master/data/radars.geojson If you go to that URL you will see the data displayed on a map. To see the raw data, click the "raw" button or go to https://raw.github.com/open-air-data/atc-radar/master/data/radars.geojson
fourwatt
It would be nice to find this information for Alaska.
It seems that they keep he information stored other then where they keep
the CONUS information.
I sent a letter to the FAA and the AirForce asking for this under the FOIA and the AirForce
refered me to the FAA which has not responded at all.
If you have any tips on where to look for this it would be greatly appreciated.
I have located the sites locations. Looking for the scan rates and II numbers.
Ken
Markb
Planet Earth
Hi all. Lots of good info coming together. Here in So Cal, I'm getting a good handle on the locations and ID's of many of the sites. My big question is whether the rotation rates are either 6 or 12 *exactly*, or is it a rounded figure. When I run the BF tool, I get some wildly fluctuating rotation rates or rates that are no where near 6 or 12. Overall I get some positive results, but still not where I would hope it to be.
Oh, and by the way, good luck trying a FOIA request from the FAA. I submitted mine a year ago and they still can't seem to find the simple data I requested.
At least with all the TIS-B traffic lighting up, I almost don't need BF :)
Sharer "ba"
kma371
Sharer "ba"
Hey Mark. I have some sites I can send you from my FOIA request. PM an email address.
Bill
zj
D
DaveNF2G
Guest
It does not show any sites in New York state, but there are several.
