Atlanta P-25 Poor reception on 996
Julian1
Birmingham, AL
I've made a couple of trips to the Atlanta Airport area recently. Tried the new ATL P25 on my 996.
Lousy performance on 996. Suggestions ???? Operating conditions as follows:
I had all the talkgroups set for Digital Audio
Operated in Search mode to p/u any talkgroup
Parked stationary on Virginia Avenue
Frequencies set NFM, which I normally do
Antenex ABSCAN scanner antenna.
Very strong signal displayed - also tried w/ atennuator - no improvement.
I operated w/ P-25 in "Auto" format where the scanner automatically sets itself to best de-code audio.
I tried in "Manual" format and would adjust between 6 and 9.
I also tried in "Default" format.
I was so disappointed at the lackluster performance of my 996 on ATL system.
Got way less than 50% success and very inconsistent.
I have seen some posts that indicate GRE/Rad Shack is better at decoding.
I was told by one that scanners have trouble decoding w/ multi-site transmitters. Slight difference in digital data stream. Well, what else did the designers expect in major metropolitan areas?
b7spectra
EMS Dispatcher
Cobb County, GA
I put my 996 on the Atlanta System right after they went P25 and haven't had a problem with it. On my 396XT it even sounds better. Haave you got the latest firmware?
BTW - Coming to the ScanIn?
rmiller818
Marietta GA
You must live in some magical part of the county were everything is decoded perfectly.
I am in a bad spot for reception apparently, my Pro-106 outperforms both the Pro-96 and BCD-996 that provide the Fire and Cities feed for ScanCobb, but even then I do not get perfect decoding on my 106.
Listening to Atlanta's P25? forget it.
b7spectra
EMS Dispatcher
Cobb County, GA
No, just live at the base of Sweat Mountain (can't afford to live ON the mountain). When I head to ATL, I always switch my 996 over to the Atlanta DTRS and listen to it with ease. I'm using a Antennex Phanthom on the top of my truck as well. Even at ATL on my 396XT the reception is excellent.
Metrofire31
Auburn-Opelika, AL
I live in Smyrna and get a good signal on Atlanta DTRS. And when I drive to work everyday at Emory, I get great reception in my car (BC396T/RH96). In fact, I like the new digitial systems Atlanta and DeKalb now use much better than their old analog systems.
