ATS 25 reading 000khz, and wont accept keying any frequency...
Garcma3
Black Hammock Island, Florida, 32226 USA
Hello, All, I am new to this platform, and I have an ATS25 (front) ATS-25 (rear), Ive used for a few years, and when I tried using it again, On booting up, it boots up, but all frequency is 000khz or mhz. You cannot manually key any frequency in either. Have tried everything, the FM/SSB,USB,AM switch on back. Wasnt sure if there was an easy fix, or will I have to download the firmware again? If so, is it possible to "up grade" the receiver to a waterfall? It has worked without issue for several yrs. This unit has the PCB material on front and back, and not aluminum. Have several other SDRs and other radios. Wasnt sure where to obtain the loader, or Bin file, or whatever the file is called. Thanks in advance for any help.
