Attenuator Needed for SDR radio using SDRTrunk?
kingshootr
Glendale, AZ
I've been over in another thread working to get a cleaner signal for a talkgroup that seems to be overpowering my exterior antenna. This is the thread - if you have the patience it will probably answer many questions regarding how an attenuator may help.
SDRTrunk - How to Import MCSO
For those knowledgeable about these sorts of things, can you provide any guidance as to if an attenuator would help, and if so, what dB/size would you recommend.
merlin
DN32su
Strong signals can often benefit from an attenuator.
How much is up to the level you are getting.
If you use RG-6, attenuator pads come in 3 to 20 Db sizes, just insert inline.
Another factor can be strong out of band signals like broadcast that can overload your front end
causing birdies .
For that, usually a broadcast reject filter will help.
kingshootr
Glendale, AZ
All my connectors are SMA. This is a quick video I did showing what I'm getting right now.
Does it provide enough info to make an educated guess what might help my system out?
merlin
DN32su
Try a manual IF gain and turn that down a few Db. That is a try and tweak til things look good.
I know if i adjust the IF gain over 12 Db, it overloads. +8 Db is about my sweet spot and can still get rather weak signals.
KMG54
Easley S.C.
I have natural attenuation in the spring summer and fall. Buried in the woods trees thick, higher than the 3 story house by quite a bit and here is my screen shot. Have to go down more in gain in the winter. The paris mountain tower is 25 miles from me, the mini diamond discone just hanging on my deck railing. Hopefully I can post the picture as it seem that screen capture has moved to clipart. 1689724261201.png
KMG54
Easley S.C.
Here is my extensive planning on the antenna mount and the surroundings!20230718_195655.jpg
KMG54
Easley S.C.
And Rg6 Quad shield. Works great, those small wave lengths bend just fine.
