DSDPlus dsd plus help-Registration req'd;
bianco99
Hi everyone,
I recently started using DSD PLUS fast lane.
I have several frequencies modulating in DMR, some of which I can listen to without any issues, while others only display messages as shown in the attached screenshot.
For receiving the analog signal, I’m using SDR paired with an RSP1B.
Could you help me by providing guidance on how to receive these frequencies where it says "Registration req'd; req'd;"?
Is it a crypted transmission?
Kind Regards,
Alf
mtindor
FMP24 PRO USER
Carroll Co OH / EN90LN
Hi everyone,
Kind Regards,
Alf
Registration required has nothing to do with frequencies
If you really want to monitor all data/voice, you really need to use FMPP + DSDPlus Fast Lane and ditch SDR software. And you need to know the active frequencies for each DMR site you are listening to, as well as their LSNs. If the site / system is listed in the RadioReference database, the information you may need will be there.
What you are monitoring is a TIII Control channel. And there is a good bet that you'll never hear voice traffic on that control channel, as Tier III control channels more commonly are only data-only. When you see mentions of VOICE instead of DATA, that is when you should hear something, as long as its not encrypted.
Read Notes.txt and DSDplus.txt and FMPP.txt from top to bottom, as many times as you need to in order to understand how to use the application
