Audio from radio while encoding QC II tones
firemun
Concord NC
I hope I can explain this without causing too much head scratching over what I am trying to convey. The common use of the term tone in multiple contexts is a bit confusing. My apologies.
When I am using my Motorola HT1250 to encode QC II tones, the radio plays a steady “tone” over its speaker for the duration of the encoding process. I want to either mute this playback tone or allow the QC II tones I am encoding to be the audio that is emanating from my portable. I have clicked through the options that seem relevant in the CPS but have not discovered the option that will disable the audio I am hearing. Thanks in advance for any suggestions.
SteveC0625
Order of the Golden Dino since 1972
Northville, NY (Fulton County)
Signaling --> Quik-Call II System --> Quik-Call II System -1 --> Basic tab there are two check boxes for PTT Sidetone. I believe if you uncheck both boxes, the Alert Tone will not sound while the QC-II tones are being transmitted. However, you might want to use the Short PTT Tone. It beeps where you start the page and again when the page is complete. That way you'll know when you can begin voice transmission.
firemun
Concord NC
That took care of it. Much obliged!!
