I recently purchased from Amazon a Sangean DAR-101 Digital Audio recorder and a 32GB SD Card for a little over $100.
I'm very please, connected to Uniden BC895XLT via the line out of the scanner. (the recorder also has a built in mic and connections for external mic). The recorder has what Hams call VOX and Sangean calls VAR for Voice activated recorder. With the recorder set to a record quality of 64kbps the 32GB SD card will hold over 1,000 hours of audio! Even without VAR turned on that's enough to recoded for over 40 days! With VAR pausing the record function when there is no audio, I would not be surprised if you could get 2 months worth of recording, depending on now much radio traffic you are trying to capture. Too many other feature to list, if your looking for a recorder this would be a good pick.
