Audio recording from HM782
phadobas
I wanted to get advice on how to record audio externally, not on the SD Card, from an HM782. There is the accessory connector on the back. What is the pinout and what pins have the audio? Once I know, I suppose I can make a cable that has a 3.5mm connector on the other side that I can connect to a recorder.
Or the other option, connect the radio to my computer network, and configure it to forward audio packets to a PC. But in that case, what software can I use to record?
VK6NCB
blue and red are speaker
green is ignition sense
yellow is a loop that forces the radio to use the external speaker
be aware that it will be controlled by the volume knob, its not a line level output.
  • MD78X Technical Bulletin External Speaker .pdf
