Audio/Video Streaming Attempt.
kc8qch
Cincinnati, Ohio
Hello all,
After looking through some of these posts, I put together an aduio/video feed of a pro-96 scanner from the house. At this point, it only runs in Windows Media Player because I am streaming it via Windows Media Encoder.
If you all could do me a favor and see if you can connect to it and tell me what you think? Let me know if you have a problem connectiing, can;t connect at all or anything. Yes I know the audio is Ehhh but it is a facotr of the age of the scanner, the distance from the control channel and I think I have a bad audio cable. But this is just a test at this point (a beta if you will ;)
To connect, you can go to http://www.kc8qch.com/audio3.asx and this will open your media player. or open mieda player manually, click on file and open url and the url is http://www.kc8qch.com:1638.
This is only a temporary feed and will likly be taken down after a day for refinment. Thanks all.
BTW the feed you are listening to is the City of Cincinnati Fire Department, just the Dispatch talkgroup and the Fireground 2 talkgroup.
Jeff
mlinthicum
Springfield, Ohio
Connected just fine! Very interesting way of getting the "visual" along with the audio. Maybe focus in on the screen just a little more. By the way, I'm using a laptop from a parking lot in the Dayton area! :cool:
kc8qch
Cincinnati, Ohio
Thanks Mike. That's Awesome...
BTW Plans are once I get this working, I am going to feed the audio, on a parttime basis (as long as the stream is up) to the MVBN Teamspeak Server....Just a heads up
Thanks for the info.
Jeff
Dubbin
Findlay Ohio
Connected ok but things seem to be lagging a bit. Stop downloading the pr0n and it will speed back up :D
kc8qch
Cincinnati, Ohio
LOL now if I do that....what else am I supposed to do during the day ;)
Thanks all for your help. I was bored here a few minutes agop so I tried to connect via my Del Axim via the wireless here at work and it connected okay..looks pretty cool on that little screen to...so it's sitting in it's dock just streaming away LOL!
YEs I bore easily..
mlinthicum
Springfield, Ohio
Jeff, I just upgraded my WMP to ver. 11, and it working great. Did you adjust the webcam for a tighter shot on the scanner? Now that I'm home, the image looks larger.
kc8qch
Cincinnati, Ohio
Nope. I haven't been home all day to adjust (I've been at work) I won't be able to make adjustments till after I get home from work (sometime after 5:30ish). I am going to tighten the shot and see if I can illuminate the screen differently and change/move antenna's see if that improves anything....
w2lie
New York DB Admin
Long Island, NY
hmm, did you take down the feed?? I was unable to give it a try..
kc8qch
Cincinnati, Ohio
Yes. As soon as I got home last night, I started moving the computers around in the office to complete the project of rearranging the office over the weekend. The computer that was running the feed was in my server rack and it's now on the Radio Desk. I am going to make some adjustments and try to get it back online tonight/tomorrow. I will post and let you all know when it's back. Sorry about that.
IdleMonitor
The Ottawa Valley - Eastern Ontario
What is the link to the MVBN Teamspeak server? And do you have other streamers on that server as well?
Jeff
kc8qch
Cincinnati, Ohio
Well there are a couple of links. the first tis to the website http://www.mvbn.net. To access the TS server, put 67.18.58.10:8811 into your Teamspeak and you should connect. There are a number a feeds from the area in there.
