kc5bsi
I have an Yaesu FT-450d connected to a Chameleon EMCOMM 2 long wire. I had the antenna set up in front of the mobile home and the antenna ends were supported on metal poles. (You do what you have to do). The internal tuner tuned all the bands. The other day I moved the antenna to the back yard. The balun is connected to the corner of the house and the antenna end is mounted in a tree. Antenna is now perpendicular to the house and away from other obstructions. Trouble is that I cannot tune 80 meters. It tunes 60 and 160 meters but not 80.
