rocky28965
I prefer a Green background but every time I change the program it defaults back to Blue.
How can I set the default to Green
You'll need to save what you program in the software you are using to program the scanner.I prefer a Green background but every time I change the program it defaults back to Blue.
It works. You didn't answer all my questions so no further reply from me is needed at this time.The backlight color display on the scanner.
I'm not sure what you meant by 'save'? Just saving to file will not change the settings in the scanner.The backlight color display on the scanner.
I did save the change, but it still reverted back to Blue
There is a setting in the software for the backlight. The default is blue. Unless you change that setting to green and save the file, it will always revert the display to blue. Changing the color on the scanner manually does not "save" the settingThe backlight color display on the scanner.
You need to make the change in the FILE you're working with - SAVE it to your PC, then make any changes to THAT file going forward.By save, I mean saving the current program to the database.
I was assuming any changes made to the scanner settings would be retained in that file.
If making changes to the scanner settings then download afterwards and ensure the settings checkbox is checked.scanner settings
