Baofeng Baofeng programming
Stannard2
I recently learned how to use the Chirp software and was able to upload to my Baofeng. The issue that I have is when it’s done uploading to my radio I don’t know where to find the stuff that I uploaded. Thank you.
nd5y
Wichita Falls, TX
If the radio is in Frequency Mode (VFO) then you have to put it in Memory Mode (MR) to use the memory channels you programmed.
Push the VFO/MR button.
Stannard2
Thank you for your reply I was able to find where it was storing it when I uploaded it back to the radio. Do you know how to add the transmit frequency so I can listen and transmit on the ham radio part of it. Whatever admin moved my post and said that the Baofeng isn't a scanner doesn't have a clue what they're talking about.
Stannard2
I figured out how to use chirp and upload my local ham radio stations to my Baofeng but I'm not sure to input the transmit frequency into it so I can listen and tranmsit at the same time. Thank you.
kayn1n32008
ØÆSØ Say it, say 'ENCRYPTION'
Sector 001
Baofengs are TRANCEIVERS, NOT scanners.
They transmit AND receive, scanner are only receivers. So, moving it to ‘budget and entry level TRANSCEIVERS forum is the correct place for this thread.
Bob1955
Eastchester, NY
I have a friends Baofeng (new) UV-5RA and let me tell you something, it is the BIGGEST piece of Chinese garbage possibly ever made. But for free, I use it, especially in times like now but without ctcss/dcs, tons of intermod/RF. I also have the Bearcat BCD-996P2 which is a "trouble free" base/mobile scanner. I just throw the handheld in my SUV or listen to NYPD or FDNY at times.
KD8DVR
Columbus, Ohio
The Baofeng *isn't* a scanner. It is a two way radio for licensed amateur radio operators.
KK4JUG
GA
The Beofeng is a scanner like my satellite radio that will, on demand, checked the channels I've programmed into it. If that's a scanner, then I have a SiriusXM scanner.
