Baofeng Baofeng Repeater Issues
JAF27
New York
Hi,
I recently bought a Tosuny Walkie-Talkie Relay Box for my two Baofeng UV-5Rs. I was having a few issues. You see, whenever I plugin the repeater into the Baofeng, it will not receive any signals for a longer range. When I take the repeater out, the Baofeng will receive signals from that exact longer range (I tested this with my friend). I then tested this with a homemade repeater system using headphone jacks and cords, and well, the same issue occurred. Does anyone have an idea on how to fix this?
nd5y
Wichita Falls, TX
How far apart are the radios?
What kind of antennas are you using?
What kind of duplexer are you using?
What transmit and receive frequencies are you using?
Is it this?
Products like that are junk.
Only suckers who no nothing about radio buy stuff like that and expect it to work like a real repeater.
wowologist
Certifiable
CM87
Ya unless your using that parrot box in a VHF / UHF split situation...what happens is one radio end's up desensitizing the other radio. For sheets and giggles I tried setting one of these up and literally couldn't get it operate even with a 50mhz band split on UHF. On a VHF/UHF split it was possible but the delay in any decent length of a QSO is just garbage - good thing it was Amazon and away it went right back.
If you describe what your actually trying to achieve, the group here can probably steer you in the right direction and wether or not your a licensed amatuer/GMRS or plan to use it illegally on say MURS .....O IC you have a GMRS License...ya that's not going to work very well ~ you need a cheap chicom UHF duplexer with a 5mhz split.
JAF27
New York
Thank you!
JAF27
New York
Is it this?
Sorry, I am still getting new to radio. Are there any less expensive repeaters you would recommend?
RFI-EMI-GUY
The Baofeng radios have crappy receivers that are barely suitable for stand alone reception and totally unsuitable for using as a duplex repeater as you attempted. I would suggest a simplex repeater like a "parrot" box. The only one I can recommend is the Argent Data ADS-SR1 $89.00. Though there may be cheaper, the ADS-SR1 is well designed.
wowologist
Certifiable
CM87
And I don't know your exact location in NY where you would plan to do this, but make sure you scan/listen to the GMRS repeater pairs around you and pick a clear one, or one that your low power box won't interfere with another.
RFI-EMI-GUY
wowologist
Certifiable
CM87
He is in NYC. Those notch duplexers "might" work, but the BaoFeng receivers are still going to have to deal with all the various transmitters on the air.
What do mean "might" ...my neighbor in true norcal has one set up on GMRS for many years now it covers his 3 fields, is done with Boafengs and works like a charm.
JAF27
New York
Are there any repeater units that you would recommend that don't need the baofeng?
RFI-EMI-GUY
The OP is a newbie. If he spends money on a duplexer, assuming it is tuned correctly, does he have the correct cabling? (add $50) Then does he have a correct base station antenna? (Add $150) Can he measure desense? (probably nope) Then there are all the other TX's out there. NYC has a ton of transmitters that a Baofeng must deal with.
Then his follow up: "Sorry, I am still getting new to radio. Are there any less expensive repeaters you would recommend? " Therefore if he is looking for cheap way for a Baofeng with its factory antenna to act like a repeater, yes use a simplex "parrot".
RFI-EMI-GUY
A Kenwood TKR850 with internal duplexer. Make sure it is 450-470 band . Prepare for sticker shock to actually get on the air!
