Okay here is the current update. I took the straight UV-5R and used these instructions to get it back to original:
UV5R F8HP Recovery Baofeng Pofung UV5R
Then I loaded a single duplex repeater frequency with the CHIRP software and it worked!! I stood in my yard and made a contact with a friend that said I was loud and clear and it worked just fine. So that radio is working again. I have done the same now to the newer UV-5R Plus radio and it will hit the repeater and I get a response from that but it's funny the two little HT's for some reason just won't talk to each other. Maybe because they are so close or what eve I am not that much of a radio technician to know all that stuff. But I will take them outside and get another station away from me to test with and I will report back. We have two repeaters here in the Klamath Falls, Oregon basin and one uses a tone and one doesn't. I have loaded both repeaters into the two radios and I will be testing them a little later and of course report back.
For the gentleman that asked where I was located and what was I programming I am in Klamath Falls, Oregon. The two repeaters are as follows:
146.850 Hamaker Mountain Tone of 118.8 duplex of -600
146.610 Hogback Mountain No Tone duplex of -600
There are others around but these two are the closest for me and what I am trying to get working. If they work then I can reprogram the others that I use.
Thank you all for your suggestion and help. I'll report back when I confirm they both work on both repeaters and then I think we fixed it.
Again I sincerely thank you all for your continued help in solving this issue. I dearly love these little radios and I know they are quirky to get working but when they work they are solid.
Best Regards,
Lisa
