Baofeng UV-5R vs UV-B5
MDof2
Thanks Jim.
Once I get the cable and interface with CHIRP to get the config and version number / add'l info, I'll start a new thread on it should it need further discussion. At this point, I know I bought two of the same model radios, which have different features, and behave differently. Likely because of different firmware versions.
To the OP, sorry for highjacking your thread off the OT.
flashmang1
Does anyone have the default img file for a uv-5r BFS311/BFS297? I have learned the hardway of loading an img file from different firmware revisions. The one I am having trouble with will not work with the mic on radio but a headset will work. When I loaded the latest chirp I now get the message that some functions were loaded but not all due to different revision, but this is all after I used an older chirp that allowed it.
I went through similar issues when I loaded an img file from a BFS313 to a N5R-20 and I now know the importance of loading the proper img file using chirp.
What I found out with the N5R-20 was when I loaded an improper revision was the radio could recieve but not transmit. Future reference for others that may have the same problem. This does not seem to be the issue if stock software is used that comes with cable, just chirp.
Thank you for any help anyone can offer.
