Basic GMRS Base Antenna Setup
gman4661
I have a friend who lives in the middle of three GMRS repeaters ranging from about 12 to 20 miles away. Using an HT, he can't access any of the repeaters from his home, but his radios work fine in other areas.
He is exploring options for a basic base antenna and coax. Ed Fong and J-pole antennas are possibilities with maybe a 20 foot mast. The terrain in the area is rolling hills. Suggestions for an antenna and coax would be appreciated.
popnokick
Northeast PA
Here are 24 possible choices. For coax use something such as LMR400 which is lower loss at the UHF freqs used by GMRS. You'll need a pigtail jumper to connect to the HT because LMR400 is a very thick, stiff cable. Use a short more flexible low loss jumper cable indoors -
GMRS Omni-Directional Base Antennas | The Antenna Farm
prcguy
I would not bother with a toy antenna like a J-pole, get a real antenna and enjoy some long distance. I would recommend the Comet CA-712 series tuned to 460-470MHz which is built similar to the original Stationmaster antennas but at a reasonable price. Stick that on a 20ft mast or whatever will get it above roof line and feed it with some low loss LMR400 and its GMRS party time.
I've seen a few, but the symptoms you mention seem like installation issues, not the design.
The design is that it's a half wave antenna with a tuning stub and no ground plane. So it has 0dB gain, or the same as a quarter wave with a ground plane.
I ran a J-pole for a few years when I first got my ham ticket. Worked fine for my application at the time. Nothing wrong with them for amateur radio use.
It's easy to get a better performing antenna. There's nothing magical about a J pole other than they are super simple to make.
If it works for you, then that's all that matters.
As for the OP, the Ed Fongs are just wire inside a PVC pipe. It'll work better than a hand held inside the house, but for a few bucks more, you can get some gain that will improve things even more.
W8UU
Pilot of the Airwaves
Wellston OH
Get something with decent gain (look for dBd numbers, not dBi) and something sturdy. Commercial-grade antennas are the gold standard but there are some decent ham-grade antennas that will suit your needs and purpose. Use quality feed line like LMR400, get it up as high as possible, and don't forget lightning protection. There are at least 30 choices out there on quality gain antennas for 460-470 MHz. The only limiting factor is what your checkbook can afford. Buy the best antenna you can afford. You'll get what you pay for.
EAFrizzle
Bond. Ward Bond
SE de DFW
They're great as a field-expedient quickie for an HT (at least back when TV twin-lead was extra-cheap and available everywhere). The copper tubing ones are nice-looking in a steampunk way, but I wonder if the patina will affect the performance.
If the joints are soldered, then probably not. I'd probably be more concerned about them filling up with water, unless a weep hole was drilled.
gman4661
Very good replies. All are appreciated.
Apparently, the Ed Fong and J pole antennas aren't generally recommended.
Someone has suggested a Slim Jim which has twice the gain of a J pole. It's compact and very reasonably priced.
Comments please,.
prcguy
Comments please,.
I generally see two camps of GMRS users, one that uses various radios with really poor antennas and the other with various radios and really good antennas. The poor antenna crowd lives in a world that barely makes it out of their neighborhood where the really good antenna crowd is more worldly and can talk into other cities or counties. They usually run better radios but have learned the antenna is key to long distance and the cheaper radios are more of an annoyance picking up more interference and garbage but its really the antenna that puts them ahead of the poor neighborhood crowd.
So now is the time to decide, do you wanna live in a little world of just your neighborhood friends where everyone uses a J pole or do you want your radio signals to travel and see the world? That takes a real antenna up at real heights above roof line and short runs of low loss coax. Its your choice, pick a side and go for it. But if you pick the wrong side please don't ask why its not working well because deep down inside you will really know the answer.
KF0NYL
Another vote for the Comet CA-712EFC or Comet CA-GMRS if antenna length is a concern. As mentioned, use a good LMR400 coax with a smaller flexible coax to connect the LMR400 to the hand held radio. Get the antenna up as high as you can.
I run a Wouxun KG-1000G hooked to a Comet CA-712EFC with LMR400. The base of the antenna is 20 feet above the ground. I can talk on a couple of repeaters that are 50 miles away here in mid Missouri with this setup. Local terrain and buildings will effect how far you can talk and why it is important to get the antenna up as high as you can.
gman4661
Thanks for all the replies. He told me today that he is looking to spend about $60 for a basic antenna. Hopefully, he will spring for quality coax. I found something in his price range. Any thoughts on the Browning BR-6143?
