Retevis BASIC PRIVACY MOTOROLA
zecurubu
Is the basic privacy encryption of Motorola radios compatible with the Retevis RT3S radio? I have a Retevis RT3S but I can't communicate with a digital frequency that uses Motorola Basic Privacy. I know the key and even after configuring everything I can't even listen or speak on the frequency, but they told me it was compatible, now I'm in doubt.
doriboni
zecurubu
You were lied to, the RT3S (MD380 UV) is not compatible with the Motorola BP.
Only the RT3 (MD380) is compatible with the Motorola BP using a special firmware:
Is there a step by step guide on how I install this? I got an md380...
doriboni
When you download the.zip file if you take the trouble to open it, you will find a manual in several languages that explains how to install the firmware and how to use it.
I guess you haven't opened the user manual, have you?
you can read this topic too :
alcahuete
Southern California
As well, the Anytone 168 specifically has a setting in the firmware to ignore CRC. My old firmware 878 absolutely ignored CRC. And basically any radio with OpenGD77 also ignores CRC.
vselic
Opengd77 i am familiar, it actually really works. Anytone 168, it works only on conventional systems, with ras and ep on (but you need to have turned off crc setting). For cap plus systems, it doesnt work actually.
Razorback55
Could you explain the difference between a conventional RAS system and the CAP+ system?
If it is enough to turn off the CRC with the conventional RAS, what does CAP+ add as additional protection?
vselic
Honestly I dont know, but keep in mind conventional is tier 2, capacity+ is tier 3 system (trunking). Guessing radio can not handle all the data? Idk
