The manual states 2300 MaH Ni-MH 2300 MaH batteries can be used.
AA batteries are 1.2 volts.
If by new 1.5V you mean something like this...
They cannot be charged in the usuall charger for AA NiMh batterys...
You have to use the charger that comes with them...
OpicPlus AA Size Button Top 2800mWh 1.5V Battery Kit with charger
1.5V Lithium Ion Batteries - Replace your old AA batteries With a 1.5V rating, you can easily replace all of your old, non-rechargeable alkaline AA size batteries for ones that you can use over and over again. Kit comes with everything you need including the batteries as well as a small...liionwholesale.com
I like that charger. Will it charge all sizes?The article says they are size: 14500 and can only be charged with the charger they come with. My Opus C3100 says it will charge them (lithium 14500).
Opus BT - C3100 V2.2 Digital Intelligent 4 Slots
I am happy with the Nickel Metal Hydrides and I don't think I will be buying those 1.5 lithium. I don't know much about lit ion but wonder if the charger would see it as 1.5 or 3.7v. Something has to tell the charger what its charging.A 14500 standard Lithium (3.7V nominal) sure it will...
Those batts I posted have a buck conveter chip in them to drop the voltage to 1.5...
So the Opus will not charge them...
You could damage the chip by doing that...
Nope. There are sets of 3 LEDs in series, but eash set of 3 is wired in parallel. If one LED goes bad, it only takes 2 others with it.If it thinks it's a 1.5V can't very well charge a 3.7V lithium which is usually 4.2 volts when charging...
I have no use for those batt's either...
In LED light bulbs the led chips usually are wired in series... Loose one chip and the bulb is done...
Just like the old Xmas tree lights... Of course you could find the bad bulb and replace it...
Can't do that with the new LED house bulbs...
4.5 hours? Your do a discharge refresh every time?I charge them in my Opus 3100 in four and half hours
I made a mistake once and left them in over night and two of the Energizer swelled up
What brand do you guys use?
The 1.5 volt rechargable batteries are lithium. I would charged them with a charger specific to that type, not in the scanner, I would leave the setting in the scanner on NI-MH. My question is will the scanner be in danger if I use the lithium? I dont want to cook anything in the scanner the first time I turn it on.Me... I would not use them at all...
I was asking if thats what the OP was refering to when he inquired about "The new 1.5V" Batts...
