SDS100/SDS200: Battery voltage
RandyKuff
Lorain, Ohio
It can be set in the menu...
I have mine set to 3.3v...
That gives me about 6.5 to 7 hours of runtime... depending on volume and activity...
RandyKuff
Lorain, Ohio
Thats true... But the lower you set it the quicker the battery will fall in voltage under load (and give you the warning message) and shutdown at what voltage they have set for... It does not wright to the card when it shuts down...
As far as what voltage the radio will shutdown at, not sure what they set it to...
Not wise to drain liion bats below 2,7v though...
fanz1
PT ST Lucie FL
Good advice. Ty
Ubbe
Stockholm, Sweden
You can only set the voltage when the warning comes on, not the turn off voltage. LiIon batteries have internal electronics that balance the voltage between the cells, if they are several, and switch off the output before the voltage goes too low that could harm the cells.
/Ubbe
